muduck18
- Geigertown, PA
Yes but isn't mileage a great way of measuring performance?
Efficiency not performance.
And
Efficiency is not equal to performance.
Can anyone calc rpms @ 70mph with 4.10 and 4.56? 30in tires, AW4 1997XJ. Someone had posted charts but they are no longer available.
Just bought a boat to tow and would like to cruise at 70, right now 65 is all she can muster without hunting.
Auto VS Manual is a huge difference!When I drove my XJ to Winterfest I averaged 16mpg. 4.0/AW4/4.88's/33's That's nearly all Interstate driving @ 65-70pmh. I don't have a tach so I can't tell you what RPM's I run at highway speed.
What gets me is guys that think the 33's and 4.56's is the best thing since sliced bread. BUT, they've never drove a rig with the 4.88's to compare to. Before I regeared, I was running 33's and 4.10's and absolutly hated it. It was a huge dog in my opinoin. HUGE dog. I drive a 4.56's/33" rig as well as a 4.88's/33" set up before I made my decision.
Agreed, I compared several tire/gear ratios In actual XJ's before i went with 4.56Bottom line is that preference is really what matters. Some play with number and make big fancy charts with final drive ratios and some other numbers that I'm not sure what they mean. Real world experience and charts on paper don't always agree and, in my opinion....this is one of those times. You may love the 4.56's and that's fine. However, if you don't have anything else to compare them to..........:dunno:
If you're going to regear, do your homework. Drive a rig that has what you're considering. I realize that sometimes it's not doable for everyone, but it's the best way to know if you're going to like it or not.
"Efficiency not performance.
And
Efficiency is not equal to performance. "
I would tend to disagree somewhat. Efficency is a measure of performance if you define performance as the way a vehicle performs in all aspects. Otherwise if you're simply defining performance as in speed or towing what in the hell are we doing driving Jeeps anyways?
I would agree efficency is not the only measure of performance but it certainly is an aspect of it. I guess it all goes back to how one chooses to build their Jeep.
And
.... what? You don't realize it, but you're speaking nonsense.
The 4.0 is more efficiant, and has better performance, at higher RPM's.
The factory geared the way they did for comfort and emissions. end of story.
I think you are speaking nonsense.
with 4.88's and 35's, my XJ will pull 19-20 on the highway.
With 5.13's and 35's, Jes pulls 22-25 on the highway.
The BS meter is now officially pegged. I'll go 18, I'll even go maybe 20 (not really). But there is no way a not so smooth XJ lifted with 35's and running 5.13's is getting 25 mpg! Come on dude!
I've had multiple Jeeps of various styles, WJ's, ZJ's, XJ'S and a TJ. Some stock some modified. None of them approached 25 except the stock WJ.
The more energy it takes the higher the fuel consumtion. Big tires equals more rolling resistence, higher in the air to fit those tires equals more wind resistence, higher RPM to push all that thru the air requires more energy to turn those RPM's. All of this adds up to less mpg.
So what your contention is a lifted, big tired, geared XJ is getting better economy than my stock WJ. Which has much smaller tires, lower to the ground and is slicker going thru the air.
I gotta agree 100% with that. 25mpg! Come on...
Idling ALL the way down a 300 mile mountain!!!:doh: LOL
