The vultures are circling.
I can't really see ball joints causing the front end to pull under braking. I know when I lift my front end, the ball joints "unload" and create a gap.
If the brakes are pulsating, my guess is a warped rotor.
Did you feel for play in the ball joints? With the tire on the axle, grab it at 12 and 6, and wiggle to feel for play. Do the same at 3 and 9. Vertical play is usually in the ball joints, and horizontal being the wheel bearing.Well I had sometime this evening to tear into the front end of the jeep today. It felt like it had a bent rotor or needed brakes or something because when I would stop it would act like it would catch, then let off, then catch, and do that.
Long story short, I got the drivers side torn down. The rotor was straight, pads still had plenty of material on them, the unit bearing checked out fine, and then.... I looked up....
There was almost an eighth inch between the C of the axle, and the top of the knuckle!!
I tried tightening up the ball joint nuts, but they were extremely hard to tighten, defiantly more than the 75 ft/lbs that chilton recommends. So it looks like I won't be driving it until I swap over the drive train from my '93, or I buy ball joints for this axle.
