Haha
So... need some help guys. Like you seen I Clocked my tcase. And I put it all back together today and I have very limited up travel on the drivers side before my front driveline contacts the upper link. I get about 10.5" of up travel before I touch. And I still have a good 8" to go probably.
Now, the upper link in the picture is the one I made, so I switched it to the Clayton link that is .5" smaller, so I'll have .25" more clearance. Also, I was planning on getting a new driveline made once I Clocked the tcase. I called six states and they said they could make one out of 1.5" tubing, which would shave .25" off the current setup. So between those two things I'll gain a half of inch of clearance but I don't think that'll be enough to let my suspension articulate fully.
Besides getting a new tcase adapter and re drilling for not so much of an angle, do you guys have any other suggestions?
That's the clearance at ride height
That's when the drivers tire is up about 10.5"
Probably a quarter to an eighth clearance.
On another note, I adjusted my shift linkage and it works great, even at tgr new angle.
All the way forward (2wd I think)
All the way back (4lo I believe)
