dfjeepster
- Cranford, NJ
I had previously installed the JCR Unibody tie in plates which I am very happy with and which should allow me to run a decent quality bumper that will bolt on in the stock location yet be much stronger without having to pull the steering box any time I need to pull the bumper.
Here's the JCR tie in plates
Whipped up some new bumper brackets from 1/4" plate 5" high 8" long drilled accordingly
Used a universal winch mounting channel as I had it sitting around, welded up about 30 extra holes in it and trimmed the edges down to fit up to the 5" high side plates
Approach angle with the new bumper
I am waiting on my D ring mounts to fit them in, then it will all get welded up and I am planning on some tube work for side protection and a small stinger type bar in front and then of course mount up the winch and trim the front crossmember when I get the money together.
