Rear Toyota 7.5" 5on4.5 lug axle $50
Mike1331
Folsom, CA
You can bolt jeep wheels up to these hubs, brakes are great, third member in great shape... Its spring under has 3.73 gearing and would be way stronger than any dana 35. You'd just have to weld on new spring perches.
Came out of a 91 yota 2wd pickup. Not sure on width but i can get it for any who are interested.
if those shafts are 30 spline I'm pretty sure you could swap those shafts and breaks into a V6 rear end and have a pretty beefy setup.
Yeah thats what Rob was saying. the 7.5" axle is pretty strong too. I'd only wanna upgrade to an 8" to get a wider stance for the prerunner, in which case i wouldn't be able to use these shafts.
But yeah for the crawler dudes that could totaly be done if they find a 8" housing and third. In which case i'll sell the shafts for 40bucks and throw in the housing/third for free. I just want to stop tripping over it in the garage.
i like the 5 on 4.5 idea and a yoga rear end. those guys run big tires on the V6 thirds. you can do a cheap disc break conversion, and find locked 4.88 third members all day long.
I have no reason to do so as i have a cherry 44. But yes 8" parts are easy to find second hand. I ran a toyota 8" in my b2 and it only took me two days to source a housing, shafts w/ brakes and a welded 410 third all for $125. Prerunner dudes run the 7.5 rear end spooled on 35's w/ no issues. So this rear re-geared and welded would be a nice upgrade for peeps w/ dana 35's. It's only 1/2" shorter ring gear than an 8".
The WMS on this is 58.5 so w/ some spacers or offset wheels it'd work.
i meant for potential buyers, they can throw in a IFS third with 4.88s and a locker for 200$ on craigslist all day long. have a built rear end for like 250$.
I've been wondering where sean went to . It all makes sense. absurd bird.
I understand. In death, a member of project mayhem, has a name. His name was Robert Paulson.
