jjvande
- Albuquerque NM 505 burque
WHo's done it, and anyone have pics?
jwtrapper said:I would love to do this also, I have a lot of flex in the front but I am limited bad in the back because of the shocks. My only problem is I need the rear seat for the kids. Any one able to keep the rear seat?
Zacattack, that would be cool if you could get some pics of that.
jjvande said:that is precisely what i want to do.
How have the welds held up where the box meets the unitbody? I was anticipating having to make a much more substancial structure than you have...but if it works for you...then why add the extra weight. I also was thinking about using box tube instead of round. what thickness did you use?
Also...what rate shocks did you get. I've heard that the 255/78 is a good rate for the rear for some faster stuff...but i am not sure if that was with them mounted at an angle or verticle like yours...this makes a difference. right now, im leaning towards some softer spring rates and higher damping rates...say 255/100 for the fronts, and the next step up in the rear...27X/XX
In case anyone was looking:kid4lyf said:Rick Norman (Rick XTRM XJ) is running the RK rear four link kit between the frame rails and wheel wells.
