Rear lift on an MJ
oldmopars
Roy Washington
I just got my new MJ and want to do a little lifting. Is there any other way to lift without a SOA? I do not want that much lift all at once. I did a search and I had over 200 hits on lifts and MJs, but could not find anything after about 30 so I gave up. I would like to go with about 3in.
Thanks.
87 MJ
Use a full length AAL for an XJ, and longer shackles. To get the AAL to sit right, you will have to redrill the center pin hole, but its not too bad. I fit 33's with some fender trimming using this method. It flexed pretty dang good too!
Thanks.
87 MJ
