stumpXJ
- Atlanta, Georgia
Yeah, that crap is hard to put on....lol. Atleast its paintable.
Yeah, I want to add some tube fenders at some point, just figuring out how to tie it all together with the cage, sliders, bumpers etc.
Thanks!!
~James
Yep same here my plans are to finish my sliders then buy some unfinished bumpers then do the fenders and tie it all in.
How did you cut the extra metal off, was it hard? It looks clean.
I cut the bulk of the extra material off with a cut off thin wheel, then went back with an 80 grit sanding disc to get it close/flush to the body panel. Just took my time, it was fairly simple once it was solidly tacked together.
On the inner seam, you have to get pretty aggressive with a hammer to get the steel to lay down flat enough to tack it to the inner fender. I used several chip and body hammers with points, and it stretched the metal pretty good. That was probably the most time consuming part, not the outside. I left a section of the rocker cavity open (as you should be able to see in the pic) to flush out any dirt after wheeling. When I cut it open, I was amazed at how much dirt was packed in there. The dirt holds moisture, and is why rockers rust out so bad. My rockers are not rusted luckily, but I will replace them with some 2x5 tubing eventually.
~James
Does Body filler set up hard? Is that what you are talking about when you say seam sealer? I have to Massage the inner fenders to meet and weld it tomorrow and then grind everything hit it with body fill then work on the other side. I will take pics tomorrow but it is pretty strait forward like yours
it is a pretty rust free rig but with all that custom paint you should do the whole axles. makes it look real nice!You can barely see the red on the dif... Why red with the color scheme? Also, is the teal the original color?
While I was at the 2009 Cherokee Crawl, I saw what I wanted to do. It was on Jaun's awesome burgundy colored XJ from Florida. I dont have a picture of it, (perhaps someone else does), but he did a nice job of truly trimming his rear fenders.
