rear disk parts
flsurfer19
Florida
im goin to do a rear disk conv. on my 8.25 and i was wondering where i could get a complete list of the parts i would need. or would it just literally be everything off a zj to the xj? any and all help would be apppr.
Heres the shopping list...................
ZJ parts needed:
Backing Plate (Left) - Part# 4762129
Backing Plate (Right) - Part# 4762128
Brake Rotor (2) - Part# 52008184
Parking Brake Lever Boot (2) Part# 4762124
Banjo Bolt (2) - Part# J4006700
Brake Caliper (Left) - Part# 4762103
Brake Caliper (Right) - Part# 4762102
Caliper Bushing (4) - Part# 4762106
Caliper Sleeve (4) - Part# 4762105
Brake Caliper Bolts (4) - Part# 5253000
Brake Hose Washer (4) - Part# J3237672
Caliper Mounting Bracket (Left) - Part# 4796343
Caliper Mounting Bracket (Right) - Part# 4796342
Flex Line (Left) - Part# 52008663
Flex Line (Right) - Part# 52008662
Proportioning Valve - Part# 52009061AB
Parking Brake Lever (Slide) - Part# 4762132
Parking Brake Lever (Left) - Part# 4762130
Parking Brake Lever (Right) - Part# 4762131
Parking Brake Adjusting Nut (2) - Part# 4762118
Parking Brake Adjusting Screw (2) - Part# 4762120
Parking Brake Adjusting Socket (2) - Part# 4762115
Parking Brake Hold Down Clip (4) - Part# 4762125
Parking Brake Hold Down Pin (4) - Part# 4762126
Parking Brake Spring 2 (Lower) - Part# 4762116
Parking Brake Spring 2 (Upper) - Part# 4762127
Rear Disc Brake Pads - Part# 4883717AA
Parking Brake Shoes - Part# 4796337
Hope that helps a little.....
That would be for all new stuff and would cost you over $300. Go to a yard and find a ZJ pull the rear disc for maybe $50. It would take you 2-3 hours by yourself. Then buy new pads and rotors for $70-80.
Closer to $1100.
any kick in the nuts is gonna hurt, no matter how late it is. that was just a squirrel tap.
91 Jeep Project said:
Thanks for the 3 month late kick in the nuts.................:dunno:
Well, I just now checking how to do it and how much it might cost me.
With aftermarket parts from autozone and the like it's closer to $550, which is the price of teraflex kit.
I do count the combination valve in though.
Andrey
Or find a wrecked liberty, the newer ones have 8.25's with discs already on them.
Or a wrecked ZJ. Thank you for reminding about liberty.
Used parts definitely a way to go.
Yea, but the advantage of the KJ is you don't have to grind open the hole for the axle any...
