Rear axle shock mount replacment needed asap!
Draven1474
ogden
The rear shock mounts on my 2000 xj are done for! The previous owner cut and welded the mounts to raise them, and the welds are nasty. Plus they are a little bent up from rocks, (I did that) and as of tonight the bolts for the shock pins both broke. so basically I need new rear shock mounts for my axle, were can I get these? any recommended brands or styles?
Tnt, Ruffstuff, Clayton? Take your pic.
Not that it helps you now, but i usually take the time and effort to remove stock 8.25 mounts cleanly, then resell them to people in your situation. I dont have any lying around at the moment, but theyre out there! Post up in your local chapter.
Worse case scenario, have someone fab you up something, those total chaos tabs are waaaay overpriced.
