Mud Shark said::flamemad: :flamemad: :flamemad: :flamemad: :flamemad: :flamemad: :flamemad: :flamemad: :flamemad: :flamemad:
FUCK ALL OF YOU!!!!!!!!SORRY I ENJOY MY JEEP FUCK THIS SITE!!!!!!!!!!!!!
Boggin_xj said:i need pictures of a 4dr cherokee with the back cut off and a window installed, any good links you guys know that will help me threw it??? thanks
Toyman said:Finally I have some wheeling pics with the new set up, here is a link:
I can't post for some reason. Maybe someone here knows how to post it for me??
99XJ
4.0L
4" Teraflex coils, 1" coil spacer
3" Skyjacker leaf's, 1.5" RRO shackle from first BB
4.56's
Powertrax No-slip in Chrys 8.25", open front HP D30
33" LTB's on 15X8
Bu$hwacker flares
HD tie rod bar
RK HD trackbar
RE UCA's
RE SF LCA's, custom machined and adjustable
Teraflex T-case skid
gas tank skid
3" bump stops in front
OT said:That's what it's all about, right?
Keep an eye on this site.
http://128.83.80.200/TACO/scarysteering.html
You may end up famous.
Actually......OT said:Since the body isn't a top priority, go with an interior cage.
If you don't fix that, I'm fixing to have a new sig quote.Haleyes said:Actually......
If you're going to go with a cage, go exo-cage. The problem is the vehicle has no frame (unibody) and therefore any internal cages are a waste of time. They won't hold up and they won't protect the weak exterior. C-Rok's design is the best I've seen and it is completely removable (bolt-in) in the event you no longer want or need the cage.
Screw it, I like it too much not to use it.......Haleyes said:Done.
OT said:If you don't fix that, I'm fixing to have a new sig quote.
OT said:Screw it, I like it too much not to use it.......
:firedevil
