Re Gearing
RubiconExp.XJ
Marietta,GA
Well gas costs to much and my rig eats to much of it i think im gunna have to re gear. Will this solve some of the problem with that i hear it will but thats not the only reason why im changing gears. I need to extra ratio cause i can barley make it up hills on th highway. Im runnin 33's right now what size you guys think i need like 4.11's or something like that. Give me your input.
I'm going from 3:07's to 4:10's next week and that should put me in the power band for my LT235 ATKO's. Been told that ratio is good past 31" tires,not sure about 33's...
you must be a newbie... do a search and i'm sure you'll find the answer. for the meantime, i'm running 33's with 4.56's in an auto. hope that helps.
i have 4.88s and an auto, I have both 33s and 35s (street and wheelin tires) the 33s are PERFECT with the 4.88s at all speeds, but when I put the 35s on and drive on the street I wish I had 5.38s.
go AT LEAST 4.56, but I reccomend 4.88s
Go for 4.10's if you have the AX15 manual and 4.56's if you have the AW4 auto.
