RE 3.5 kit
ebyrd10000
Phelan Ca
I have a Rubicon exprees complete 3.5 lift kit with full leafpacks
Also includes shocks and heavy duty RE extended trackbar and T-case drop kit.
Kit is complete I have the reciept its only 3 months old gave me about 5" off lift
first $550.00 takes it
Here is a parts list
RE2421 ~ U-BOLT KIT M35 REAR, YJ / XJ 2
RE3705 ~ CONTROL ARM SR2 LOWER FIXED
RE1171 ~ DISCONNECT ADAPTERS XJ/ZJ PRE-
RE1175 ~ SWAY BAR END LINKS XJ/ZJ/TJ
RE1300 ~ COIL SPRINGS XJ 3.5"/PAIR
RE1463 ~ LEAF SPRING XJ 3.5" W/BUSHING
RE1600 Trackbar
RE2120 T-case lowering kit
XJ 3.5" DT3000 SHOCK KIT
Four shocks included
super flex or ride kit? does ti have the jonny joint lower arms or fixed rummbers? would you be willing to part it out???
i need the shocks, coils, and leafs, let me know.
Thanks!
If you part it out, I want the trackbar, and possibly the LCAs and discos depending on how much you're asking.
THere ya go, if this guy buys those parts and I buy mine, you got a full kit sold!
3 months old? did it not work well for you? i was thinking to get the same lift (if its the super flex). how far toward san diego do you travel?
after looking up the part numbers i realized it was a super ride and not super flex system. still a nice lift though.
