RC or IRO 6.5" Long Arm?
If you have $10k you should be able to do a pretty good build. A basic cage would run about $1000. Frame plating $200 or less if you make your own. $3000 for lift. $2000 for wheels and tires. Gears and lockers $3000 tops. That leaves $1000 for the little things.
any reason why you're going with such a tall lift?.. you should need any more than 4.5-5 inches unless you plan on doing mud runs with it.
Pics started on "Skwirls Bulid" in Mod Tech Discussion. Yes its more for DD & Mud than Rock Crawling here in SE Texas so that's the reason for 6.5"
