You mean the skid plate? Nah my camera battery was dead when I put that on. It's real easy though. Just bolt on the front two bolts and then drill holes on the framerail for the self tappers.
It was close but not that close. They actually tap each other when I turn to the right. The axle is rotated for pinion angle. I set it 2 degrees down, the most I could sacrifice without getting vibes. RC's measurements put my front pinion angle 8 degrees down which caused bad vibes.
I am currently installing this kit and, I have frame stiffeners too. What I have done is drill 7/8" holes and welded nuts inside the stiffeners instaed of using the crush sleeves and long bolts.
I cut about 2/3 of the way through the bottom side of the bracket about half way between the end and where it welds to the coil bucket, bent it up and out of the way a little way and welded up the gap. I think I got about 1/2" higher. You could also buy (JKS) or fab up a new bracket that is a little higher.
Nice lookin rig by the way and nice job on the install!
