skyjackerXJ
- New England
Prices On Used Stuff Are My Best Guesses And May Be Negotiable. Please Make Me An Offer. All Parts Located In Fairfield, Ct Off I-95. Some Items Can Be Shipped.
Brand New Stuff:
Skyjacker Xj Rear Sway Bar Disconnects (+/-6") - $30
Skyjacker (2) Xj//tj/zj/yj Hydro Front Shocks, 30" Extended 16" Collapsed (6+ Lift) - $20 Each
Skyjacker (2) Xj/tj/zj/yj Hydro Rear Shocks, 27" Extended 16" Collapsed (6+ Lift) -$20 Each
Hella 550 Rectangular Amber Fog Lamps - $15
Used Stuff:
Mj/xj Dana 44, Metric 1-ton (dissambled) W/ 3.55 Gears And Carrier, No Brakes, Perches Or Yoke, Ready For Paint - $200
Dana 60, 3/4 Ton 30 Spline, 8 Lug Full Float Rear Axle W/ Drums And Shafts. No Gears, Carrier, Or Cover. Very Clean. This Axle Was From A Dodge Van & Has An Approx. 5"offset Rear Diff. (cut Down Long Side & Use 2 Short Side Shafts) - $100
Dana 60, Full Float Drum Brakes - $20
Dana 44, 4:10 Ring & Pinion, Reverse Rotation - $50
Dana 60, 4:10 Ring & Pinion & Open Carrier - $75
Skyjacker (2) Xj/tj/zj/yj Nitro Front Shocks, 30" Extended 16" Collapsed (6+ Lift) - $15 Each
4 Stock '99 Xj Tires On 15x7 Alloy Rims W/ Center Caps, 54,000 Miles On Treads (won't Separate) - $75
Xj Jeep Logo Slush Mats (4) - $35
1 Brand New Xj Factory Spare Tire And Rim (full-size) - $50
Mopar 8 Pair Ski Rack. Mounts To 97+ Factory Rack - $30
Thule 4 Pair Ski Rack (old Style, Mounts To Thule Rack - $15
Xj Stock Parts
97+ X-fer Case Crossmember, No Damage
97+ Rear Flares (2)
84-01 Tie Rod W/ Ends, Straight
84-01 Track Bar, Brand New
Brand New Stuff:
Used Stuff:
Xj Stock Parts
97+ Rear Flares (2)
