Random picture thread
Her facial expression just looks confused, thats the first thing I saw/noticed.
Found this out at the semi-local steel yawd...
Comes with a stove top range, gen, refrigerator and exterior lighting.
Pretty cool, don't you think.
Why is everyone hatin on his sweet exo cage???
Noice! :clap:
I think it needs to go a tad bit higer though.... hell my mom cant even get in it now and I have to kinda jump when i wear sandals to get into it, i still want it a bit higher. So i am on the look out for some front coil spacers and I guess longer shackles?
i sent you a pm
Don't do it! Keep it low!
X2!!!
Keep in mind that when you lift, you increase the CoG. Physics dictates that you want a lower CoG when crawling over rocks and on various cambers...or crawling over rocks on various cambers. The higher the body of the XJ is from the ground, the more likely it be pulled to the ground. Stability is your friend!
Alternatively, height and axle width should increase proportionately.
X2!!!
true. i want the axles i had for my first xj back.
