Radiator/water pump hose clamp sizes
gba88
PA
Does anyone know what size clamps (the constant pressure type) go on the radiator and water pump? I'm fighting a leak on a screw type clamp on the lower radiator end, radiator was just replaced I hope the stupid thing isn't cracked. I re-used the old hose but probably shouldn't have. The factory clamp was on the pump side but not the radiator side. I thought I saw once that they were all 50mm but the one on the lower pump connection was 55mm, but can't find the info again. Also, where can I find these at, anywhere local?
What type are youwanting? Flat strap, single wire, or double wire?
