Quick Tranny Cooler Install, Workin on it Now
jeepsrock
LA California
I am a bit confused right now with the tranny lines. After searching a bit i know i want to connect the cooler after the stock rad cooler but that isnt the issue.
The issue is hose id ?
I think the top Rad hose is the feed and the lower is the return. But after searching i found a thread where a few ppl points out that the upper rad connection is the return and vicea versa ???
Let me know pls..like to get this done today
Pete
Or you can jsut completely bypass the radiator, that wut i did. Then you wouldnt ahve tow orry about which line is which. Mine ahs worked out great and tranny never overheats.
Ya jeepkid , i rather do it do this way tho- but i am glad it has worked for you.
What i did was disconnect the line attached to the upper rad and fluid came from the tranny line meaning that its the feed/pressure line.
In result i had to cut into the line that runs under the oil pan which is connected to the lower rad port.
Make sense ? THanks pete
