seanof30306@yahoo.
- Tulsa, Ok
OK, so my rearend is howling like a demon. Been doing it since I bought it new in 1996, but it's been getting a lot worse over the past couple of years.
The clutches in the posi have been groaning for the past 70,000 miles, no matter how much additive I put in it.
I'm getting ready to swap out the leaf springs when I lift it, so it just makes sense to address the rear diff now. I want to upgrade to rear disc brakes, too, so now's the time.
Rather than put money into a Dana 35, I looked around at upgraded diffs. I think I've found a pretty good solution:
http://eastcoastgearsupply.com/i-4764922-ford-8-8-rear-axle-bolt-in-xj-assembly.html
These guys take junkyard 8.8" Explorer diffs and set them up to be bolt-ins for XJs (among others). There are a lot of options. I specced mine out at $1,415, with free shipping on orders of over $500, but a $200 "handling fee" (That's a lot of handling!). Total cost to me: $1615, with a 5 year warranty.
That's ready to bolt-in, with:
Welded axle tubes
Factory 3:55 gears (new gears are $250 more)
All new bearings and seals
Rebuilt factory limited slip ($300 more for a new Detroit True Trac)
factory axles (new axles are $200 more)
11" Explorer brakes with new calipers, pads, e-brake shoes and rotors.
Correct ebrake cables
Set up for ABS
I don't do heavy off-roading. The reason I ordered the Up Country package when I bought my Jeep was because the LSD made it so good in snow and blizzards. I think I can do fine on the $1415 version.
A couple of questions.
1. I saw the guys on Truck U do an 8.8 upgrade on a TJ awhile back. They said the 8.8 was 2" narrower than the TJ and XJ diffs. The guy at East Coast Gear says it's 2" narrower on a TJ, but only 3/4" narrower on an XJ. Who is correct?
2. Would it still use the jeep ABS sensor, or would I switch over to the Explorer sensor?
Welded axle tubes
Set up for ABS
