korda
- San Diego, CA
I am planning on bolting my long arm crossmember to the uniframe. I've seen a few examples but I need something clarified for me. I've read and understand that it's a good idea to sleeve the bolts in the uniframe. My question is how exactly do you go about this. I drew this picture to help show what I'm asking.
When inserting the sleeve you must have to cut a hole big enough for the pipe to fit in on one side of the frame, correct? What side should it be? Do you just weld the sleeve to the frame on that side? Should I forget that and do it on both sides? I imagine you want the sleeve to be slightly smaller than the frame (Width) so that the bolt sqeezes the frame a little and the sleeve is not carrying the load of the crossmember? And lastly, what are people doing with the brake and fuel lines after putting bolts through? Just tying them back where the were?
Thanks for the help, I know that's a lot of questions. I just want to do this right.
