Çrestfa||en
- Snohomish, WA
I'm trying to disable my ABS system. Just removed the fuse named "IGN ABS". Will I die?
Çrestfa||en said:I'm trying to disable my ABS system. Just removed the fuse named "IGN ABS". Will I die?
disabling the abs in a 90 will render the brakes useless.Çrestfa||en said:90 xj sorz
IntrepidXJ said:disabling the abs in a 90 will render the brakes useless.
SimpleXJ said:If you want another reason to ditch ABS... heres one - did you know that the pressure that pump builds can reach 3000psi and above? I don't know about you but I don't want my brake fluid pressure to be that high. If it ever burst I bet it could cut metal.
SimpleXJ
