CRASH said:OK, here's an experiment for you. Park your Jeep on Moab or Sierra rock. Engage low range, bring the RPM's to 3,500. Side-step the clutch.
The chain in 4 to 1 case sees 47% more torque than the 2.72 case.
I would be willing to take that challenge and disagree with you..... The chain and everything after it would see exactly the same either way because your tires are spinning by that rpm... But,,, everything before the reduction would see less stress....
If you can turn your tires, it isn't going to matter how much reduction you have from the chain out to the wheels as they are already at their maximum traction/load.... Now if you was to pin a tire where it would not rotate at all,,, and you bring the rpm to 3500,,,,, then there would definitely be a difference,,, and I'll bet it would be a broken axle, driveline or your tranny or clutch is slipping.....
Put some engineering into it,,,,, if it takes 1000 ft lbs of torque (at the yoke) to break all 4 of your tires loose,,, tell me your input torqe to accomplish this with the reduction of each?
