BPB NAXJA Forum User Location Battle Ground, Washington Oct 9, 2011 #1 Is anyone running a fuel cell? If so what fuel pump are you running and were you able to mke the factory fuel guage work?
BRIANHO13 <- Yum Chocolate Location Spring, TX Oct 9, 2011 #2 This is what I am using. http://www.polyperformance.com/shop/Gen-Right-Jeep-TJ-LJ-XJ-Aluminum-Pump-Rings-p-17431.html
RCman NAXJA Forum User Location USA Oct 9, 2011 #3 My setup: Out of 70-micron Walbro pickups/filters from the cell --> Earl's Shut-Off Valve --> 4060FI pump --> 4305M return reg --> EITHER back through another Shut-Off Valve and into the tank OR onto a 10-micron filter --> pressure gauge then finally into the fuel rail. My dash gauge isn't hooked to anything, so it just stays on 'E'. It is a trail only rig so I don't really have a need for a gauge, simple enough to just pop the top and look inside.
NW-ZJ-SCOTT TEXAS-JT-SCOTT NAXJA Member Location NE Texas Oct 9, 2011 #4 BRIANHO13 said: This is what I am using. http://www.polyperformance.com/shop/Gen-Right-Jeep-TJ-LJ-XJ-Aluminum-Pump-Rings-p-17431.html Click to expand... Hell, Now i'm interested in going with a Cell!
MoparManiac NAXJA Forum User Location Amherst, NH Oct 10, 2011 #5 RCI2161A with YJ pump assembly (I have an OBD-1 MJ). Cell has a built in check valve too. No pickups inside the cell, works just fine as long as there's more than 1-2 gals left. Fuel gauge doesn't work quite right. Not sure if the float is stuck on the existing return tube or not, never bothered to check. Mounted in the bed, as far foward to the cab as possible.
