XJ Dreamin'
- Huntsville, Texas
You may know from a recent post that over the next year I will be doing some mods to my stock 2WD '93 XJ. One issue will be opening up the intake. I'm looking for improved streetability without sacrificing rough gravel/native surface performance. I'll be looking at boring the TB to 60mm and porting the intake manifold to match (or is it already 60mm? I forget). There will most likely be a TB spacer as well. To my mind, I like the shortest possible distance between the filter and the TB. Also, I don't like pulling air from the engine compartment. So, while some high flow filter will be involved, I don't really like the air tube FIPK's that I've seen. I understand they are a worthy improvement over stock, but I'm just not satisfied with that setup.
So, I've been thinkin'. The shortest possible distance from the filter to the TB is to stick the filter right on the top. Of course, you need to connect the CCV pipe and the canister pipe, and NO I'm not going to have a K&N cone filter sticking out the top of my hood. But, here's what I'm thinking. Adapt a round filter, carb-top style intake housing to the top of the TB. The CCV and canister pipes can attach to the bottom of the filter housing. Cut a hole in the hood just for the filter. Cut down the filter housing top to seal the top edge of the filter but not cover the sides. Constuct a seal between the filter base plate and the underside of the hood (hood up - no seal: hood down - filter is sealed off from the engine compartment). Now, cover the filter and the hole in the hood with a scoop open to the base of the windshield. It's minimal sheet metal mod. The trickest parts are mating it to the TB and arranging the underhood seal. It would have to be as open as any other system at idle and off the line, plus you get induction at speed and it's all cool, clean air. I know the snorkle folks claim some induction as well as cool/clean benefit but, frankly, I won't be seeing any water that a hood induction won't handle. Maybe I'll mount a snorkle blank anyway, just for the poser effect (Beezil fishing :laugh3: - no harm intended).
I'm pretty serious about this. Tell me why it won't work. Tell me I'm an idiot. I've worked on MOPAR all my life (my Dad maintained his own fleet of them - he had five drivers in the family). I am currently without welding capability unless I borrow but I don't see any need for welding here. A nice aftermarker or pull-ur-part rivet-on scoop would be fine.
XJ Dreamin'
stock 2WD '93 XJ, 4.0L HO, AW4, LT 235/75R15 A/T's
XJ Dreamin'
