He only had one, other wise I would have gladly snagged another for you or Talyn. He did have a nice compression tester that I was interested in, but he wanted $90 for it and it wasn't worth it to me for as much as I wouldn't use it.
I've been tracking my costs for this project. I don't have good comparison numbers yet since I haven't actually made any bracketry to this point, but here's what I have:
Used M90 supercharger $300
Set of 3 AEM gauges (vac/boost, AFR w/ UEGO, oil press) $250
Air oil separator $17
HD Offroad frame stiffeners, full set $330
Gauge pods $50
Used A/C compressor mount $10
25' each of red and black 2AWG battery cable $50
Battery cable terminals $30
Panel mount battery studs, pair $15
Jegs 70mm idler pulley $20
AEM F/IC-6 $360
Venom 30lb injectors $130
ODBII USB adapter with ODBwiz software $45
Gate belt alignment tool $25
Air intake filter, hoses, and parts $120
Misc. supplies $80
Total so far: $1832
(Keep in mind almost $750 of that would have been spent regardless of the kit selected for stuff like gauges, frame stiffeners, AOS, gauge pods, ODBII adapter, etc.)
Here are some expenses I know I still will have:
Pulley Boys 3.0" 6 rib pulley for M90, keyed $80
Heat blanket for intake manifold $35
M90 refresh kit $100
-OR-
M90 full rebuild $700 (OUCH!)
Sacrificial XJ throttle body $0
Steel and Aluminum stock $??
Machining costs $??
New serpentine belt of correct length $??
Points of note for comparison.
- The eBay / Craigslist Rimmer kit included an M62 of unknown state for $300. I broke even there.
- The eBay / Craigslist Rimmer kit wanted $700 for the SplitSecond injection controller with already-built patch kit. I picked up the F/IC-6 and Venom injectors for under $500, and ended up with I consider a better setup (no 7th injector). I don't mind doing the wiring myself.
- The eBay / Craigslist Rimmer kit was $1000 for mounting hardware, idler pulley, intake hoses, and 7th injector setup. So far into that I have all of $140. I don't expect at this point to spend $850 on materials, machining costs, and a belt.
- I'm not going to have to cut a hole in my hood.
- I will have the option to add an intercooler.
