Looks good man. Where are you at in the Bay Area?
I'm from Pleasanton too. Keep an eye out for an ugly greenish/blueish cherokee with a hack ass hybrid cage with some dude driving like an idiot cruising around town. Hope to see you out on the trails!
No wasn't really having issues. I got it as a Xmas gift.
but it's really cheap and good to have.
I just saw u added me on insta haha.
Do ya have an instagram account? Mine is @project_rudolphxj
Similar radius arm setup as you. But it's Rubicon express long arms
Nice rig...little heads up I installed a few of those Rugged Ridge sye's for customers. Remove the rear plug on the extension tail shaft housing (thats the housing where the speedo gear goes into) there is a plug to the left of it, remove it and try shifting it. Problems that were occuring is the selector shaft is contacting the housing and preventing it to shift through its rangss.That more than Likely is your problem. The fix is to Losen the 10mm bolts and reclock the tail shaft cone so the selector shaft is centered.
The correct way is to seperate it and re rtv that tail cone..align then bolt on...the rtv might be elastic enough that you can just move it the 1/16 of an inch...if you used a gasket if its felpro its fine (didn't even know if they make them)
If this was the issue, would i be able to push the lever into 2wd and still have it not shift out of 4wd(which it is currently in).
I have those on mine
