Mark817XJ
- Fort Worth, Texas
Hi,
I've been here lurking for a while now, all while gathering parts and ideas. I'm almost to the point of cutting up my XJ so I figured I'd start this thread to list my plan and get input.
My plan so far:
1989 XJ-4D 95k on the odometer
1985 Ford Dana 60 Front DRW
Engine/Tranny - 4.0L w/ got propane kit and stock AW4. Way down the road I'd like to do a 5.3L/TH400/Atlas
Tube work will be 1.75"OD .120 wall DOM; I'll cut away all but the "frame rails," and firewall from the firewall back to right where the stock rear seat ends and the rear fender well begins. Engine will be caged and radiator moved to rear. I'll maintain a near stock wheelbase, maybe slightly streched but will only have two seats with small storage behind the seats. Dual propane cylinders over the rear axle.
3-Link with pan hard bar up front
Triangulated 4-Link Rear
Fox Air shocks on all 4 corners, size and version TBD
37" tires (currently have TSL's, will probably switch to red lables)
I'm sure I'm forgetting some but I'll update this coming weekend with pictures of progress to where I stand right now.
Currently I have both Axles, the 14-bolt is complete and ready to go minus the truss and I'm about to start the 60's overhaul.
Jeep, wheels and tires are here and I just finished my got trikes bender and ordered my dies.
Friday I'll be ordering Bend-Tech PRO and hopefully have some layout work done so that I can start laying out my links in the calculator.
More updates and pics to follow. Along the way please comment. This will be a slow build by most of your standards as I'm building as funds become available. I fund most of my hobby with side work and over time, which takes from build time.
EDIT: The thread title should have read Handicap Accessible, I'll be building this rig with one hand because thats all I have use of, along with the help of some close friends.
My plan so far:
- 35 Spline inner and outer shafts
- Drive Flanges
- Lockrite or equal locker
- 5:38's
- 1410 U-Bolt Yoke
- Stock shafts
- Blue Torch Disc Brake Brackets
- Chevy 1 Ton Front Disc, Rotor and Calipers
- Mini Spool
- 5:38's
- 1410 U-Bolt Yoke
