gone2lakexj
- Franklin, TN
The next step after the lift... I took my perfectly good power window, door lock, power/heated mirror exquipt doors and cut them all to peices... here is what I have so far
Removed the doors (Pain in the *** )
I then removed all the paneling, mirrors and guts, taped my pattern and started cutting
Next I cut out the entire panel on the inside all the way to the edge.. This way I could put stronger steel all on the inside to help strengthen them. I stenciled out a patter on some 18 guage sheet and used a plasma to cut out back panel and filler panels
Then I welded on the back panel and the filler panels, saved the door handle and lock on the outside, and used an old gm handle for the inside ( I will have more pics of in between stages soon) But this is a pic of the completed door minus primer and paint and canvas
