Upper links need more horizontal separation at the frame side (more triangulation). You will probably need to do that by making them shorter, no there's nothing wrong with that, especially with your driveshaft length. Take a foot out of them, leave the vertical separation the same between the uppers/lowers, and cycle the bump/droop to check the anti-squat change, and make sure it doesn't do anything wonky (it shouldn't). Pinion will twist down at droop but anti-squat will likely go down at droop and increase at bump; these are both fine. The rear roll axis isn't going to get any better but roll understeer is usually a compromise of having low-ish anti-squat and is way better than roll oversteer at speed.
Links only function in tension & compression. It's all trig. Those diagonal links have to laterally locate the axle so your lateral component of force comes from the sine of the angle of separation. With minimal angle you wind up with a much higher force vector in the link and that all goes into loading the heims which will wear them out much faster, and cause the axle to move side-to-side a lot more when they do start to wear. One thing that can help in that department is to use the Ruffstuff upper mount (or something like it), which is what I did:
This gets you a few benefits; one, you can space the joints closer together because you don't have to worry about fitting a nut/washer/wrench/etc in the space in between which helps you to maximize the triangulation, and two, you're loading the ball against the solid part of the heim body instead of trying to push the ball out the side of it so in theory you should get a longer life out of the joint.
Overall I'd probably want to shorten everything up...what I'd probably do would be to look at your breakover angle from the side and if you do have to put the links under the frame, keep the mounts within that boundary so they're not your ultimate limiting factor.
