Getcha_Sum
- Great Falls Montana
36" SS IROK's brand new never used $625
5 on 5.5 black steel wheels $125
Stock front 86 cherokee driveshaft
D30 axle shafts $20 each
hub ass. $20 each
D35 axles shafts $20 each
Ford F-150 D44 High pinion front axle. 5:13 gears New wheel bearings, over knuckle steering, 1/4 inch diff cover,heavy duty tierod with new TRE's 6degree c bushings with custom radius arms using rubicon superflex joints on the frame end.
Rusty's skidplate with brackets for radius arms welded on.
Entire setup ready to install along with trac bar and 6.5" coil springs giving about 8.5 inches of lift, Stainless Steel extended brake lines. Entire setup $600
Rear Ford 9" 5:13 gears Spool, Mj leaf springs giving about 5 inches of lift with brand new poly bushings new U-bolts, stainless steel extended brake lines Entire Setup $400
Tan leather Steering Wheel out of 86. $25
2 rubicon super flex joints and tool used to tighten $50
Everything in located in Great Falls, MT
If you need any pictures of anything I can e-mail them to you.
hub ass. $20 each
