Time for me to join the class I think! :wave1:
Haha... I really don't think there is much one can learn from me. Maybe I try to be too humble.
Anyway, Ghost was asking about my high steer arms in another thread. I'll post what I responded to here so all the information is in one place.
From the other thread:
What did it cost you to make those arms? I have no access to anting like that ATM but I do have people I know that are machinist. Would you consider sharing you plans with me to see get a price quote from a friend? If not I understand.
As for the plans for the steering arms... I never made any real official drawings of them. I've got a few sketches on some paper and those plywood mockups. I could quickly dimension it all out for you if you needed and send it your way if you are truly interested. Let me know and I'll get on that sometime this weekend.
For the cost of the steering arms, I couldn't even throw a guess. Of course I didn't pay for my labor and I got the 4140 alloy steel relatively cheap (which is really overkill, 1020 or 1018 would probably be fine).
The above being said, you can purchase high steer arms from a few companies that are already offset for the H1s. I didn't do that for a few reasons.
First, most of the ones that I would have been able to afford all retain the use of the stock cap. If you look closely at the cap you'll see that it has a pretty decent fillet around the edge of the spring retainer before it gets tot he cap bolts. I didn't like the fact that the inside of the arm would have to get radius'd to clear those as in my opinion it makes for a kind of weak setup.
Secondly, most of the arms are only 3/4 or 1" thick and do not have an angle on the end to correct for the proper alignment of the joints. Sure, I could have added it myself, but at the 9degrees it takes to correct the angle the material thickness drops almost 1/4". I didn't feel that 1/2" (starting with 3/4") or 3/4" (starting with 1") was enough. It probably is, but I just didn't want it if I was going to be using a 3/4" bolt. By starting with the 1-1/4" material that I did I was able to retain just over 1" at the end after the corrected angle where the bolt goes through.
Third, I just plain enjoyed making them!
Sorry for the long winded post, I probably have to much thought into it.
Again, let me know if you want me to create quick drawing for you with dimensions and I'll do it.
Hey what happened to picture day?
I feel like something is missing in my week....
BTW :worship: awesome work.
Thanks for the props!
Picture day went out the window last weekend when I realized all that progress I made the weekend prior was good, except that the tire contacted the coilover with about 3.5" left of compression to go. Took almost all day Saturday to rework the mounts and angle them as such that I could use almost all the 14" of travel. It took a lot of time that I didn't expect as it was a bunch of "tack, assemble, flex, remove, repeat" until I got a happy medium. Tedious, but not much I could do as I don't have much room back there due to the spacing of the H1s.
As I have it now, I am limiting myself by 1/2" uptravel and 3/8" droop. No big deal really as I would need to have the bumpstops and limit straps stop the suspension before the coilovers reached the end of the travel anyway. To give you an idea of how much I moved it, I was originally looking at an angle of 8 degrees outward with the hoops. After all said and done, I'm now looking at about 2 degrees inward. It doesn't look at shapr anymore, but it functions much better. I'll get some better pictures up hopefully this weekend.
As with everything I've seen to have done with this build, had I known about this I would have done some other things differently. Mainly with the replacement rails out back.
