John D
NAXJA Member # 788
- Rockford, Mi
Re: Project "Spring Semester Of 2011"
Your tap is 5" long? Think of how long the bolt is, that's how long the tap would need to be to reach through the frame. Even if you could find a tap that long, it's a bad idea to try to do it through the frame. Think of it like this, you couldn't even get a bolt through the frame and threaded correctly; how are you going to get a tap through and threaded correctly? Just take it back off and do it right. It will cost you an extra hour, but you will be happier with the results.
