My apologies, I will not muck it up any more.
i mean... jeeps in general are a pretty poor investment strategy. lol.I'm sure it would be OK to leave it as is for just a DD but for me I'd rather have it over done since I will put this thing to work and would rather not deal with it breaking again. Eventually this will end up being a really capable offroad rig so its not a bad investment IMO.
Thank you for finishing what I started man, it's really great to see it getting done since it would still just be a lawn ornament for me. I fully approve of the direction it's headed, keep up the great work!
What all does the 2dr need/you want to do?
Ah ok. That is a tough call. You can fix it to sell or fix to keep.
Thanks. I think it will look much better in the end.Very cool, I approve of the blue, looks great. Blue was the color that I was going to paint it originally, hence the name of the thread...well...sort of.
I spent quite a bit of time looking and everything is out of the way. It's just the ring on the engine side of the TC that is not sliding in. I can of course get one side to slide forward a bit but that binds the other side. I just can't get enough force on the trans to maneuver it just right and push it on at the same time. I'm starting to screw up my back from all the pushing and pulling.What is it thats holding it back? Ive had to use a pick to try and pull the converter to the plate. Also have had the tab that bolts the trans tube get stuck between the trans and block that wouldnt let everything tighten up correctly.
Id swing up but cant this weekend as its prep for my trip to Iron Range next weekend and im still moving slow due to the back.
