tribal_4x4
- Roseville
Ok so I need some help from you guys. I went to smog my jeep and it failed.... barely... It missed the first time by 3pts on HC at 15mph
So i did a few things. I swapped in 703 injectors, I replaced my AC Delco plugs with Champion Coppers. Cleaned my throttle body completely and properly adjusted my TPS. Also Seafoamed it twice. I notice for a few days the jeep smelled rich even after I initially hard reset the ecu for the injectors. I go back to smog it anyways and the results were astonishing...
I turned into a gross poluter instantly... not too freaked out about it, I quickly ran home swapped in my stock injectors and the jeep went back to normal. I smogged it shortly after swapping back and it put up the same numbers it did the first time
Anyone know why I was running so poorly with the 703's? I did get them from the JY and I didn't "rebuild" them i just used new o-rings. I also noticed my idle on cold starts was really bad and sparatic until it warmed up.
But my main problem is I am still not passing smog and its just barely not making it. I installed a new o2 sensor today and the "old" one didnt even look old... so Im wondering if I should replace my catalytic converter? I have brand new cap, rotor, plugs, wires, coil, distributor, tps, iac, cps and now o2 sensor. Im not convinced the o2 sensor will fix my problem. Im getting a new cat tomorrow though
