Boatwrench
- Petaluma, CA
I have been battling a problem with my 1990 2WD 3/4T Suburban, 454cuin (7.4L), THM400 3-spd auto, and 4.10:1 ratio. The odometer is pushing 151K. The majority of this vehicle's mileage is from highway driving. It was used for family vacations across country (2x coast to coast and 4x to midwest IA, MO & MN) from California. 50% of that time towing a 4k lb trailer.
On Sep 6, 2008 it ran hot (sans trailer) and needed a tow home. Checked it out and the Thermostat had stuck closed. I replaced the thermostat and the vehicle continued to run warm. I drove 1K miles round trip to SOCAL later in Sep. and it was warm, but not hot. The fan clutch wasn't working and there was weeping at the w/p. I said heck with it. Recored the radiator, replaced all the hoses, cleaned the fins of the condensor, oil cooler & trans cooler, flushed the heater core. replaced the w/p and fan clutch. Some where along the way the interior lights were left on for several days and the battery was replaced.
Getting ready for Fall Fling 2008 and it started running like crap. Low power on freeway, sluggish 2-3 shift, the timing was 12* advanced and not settled swinging from 6-12* BTDC, spec is 4* BTDC, set a code 43 (knock sensor).
Since then:
Replaced catalytic convertor. (8psi back pressure) 3" exhaust from collector on back. No change
Replaced Vibration dampner (had a squealing belt & harmonic vibration sound at freeway speed also) No change
Replaced Knock sensor (code 43) Still sluggish, doesn't set codes.
Have now gone back to basics: Mechanical, Fuel, Electrical
Yesterday:
Checked timing measures 4-6* BTDC (spec is 4*)
Manifold vacuum measured with very slight fluctuation (15-17).
Compression test:
1 = 155; 3 = 145; 5 = 155; 7 = 145
2 = 150; 4 = 160; 6 = 150; 8 = 150
Plug condition:
#2 & #8 sparkplug boots were torn.
#7 and #8 sparkplugs were dry fouled (soot or oil) electrodes were black, not the pink carbon color.
The plugs in the vehicle are AC-Delco CR43TS, what the catalouges list as the standard plug.
Air filter element clean. Has 2,500 miles on it.
Fuel:
Have not checked fuel flow or pressure yet. Vehicle has Throttle Body Injection and I can't find a tap to check pressure. In tank pump and sock. Fuel filter has 2,500 miles on it also.
Electrical:
I'll pick up wires tomorrow on the way home from work. The plugs? My Mechanics Encylopedia I can't locate but it had a great explanation of when to change the heat range of the plug. Any suggestions?
Thanks in advance,
Tom
Since then:
Yesterday:
Compression test:
Plug condition:
Fuel:
Electrical:
Thanks in advance,
Tom
