Price Check On 89 Xj
Ok, here's the deal: I have an 89 XJ I've been getting ready to work on with the idea of putting on a 5.5" Rubicon Express Lift. Interior of mine is trashed, along with both axles (Unit Bearings shot up fron, bearings in rear shot as well). I have a D44 in the yard destined for it as well.
At any rate, I just test drove another 89'' that's for sale in my neighborhood for $3,800 asking price. Here's the specs:
89 4.0 Auto XJ with clean interior (has I think the Laredo package with gauges, power windows etc.)
Rubicon Express 6" rear springs
Procomp smei-6" front lift (has Procomp lift that I think was originally 4" with 2" spacers under the coils).
Confers-style roof rack
32" BFG MT tires (approx 50-60% tread)
1" Transfer Case Drop
New paint job (white)
________________________________
Engine compartment needs some minor attention, mostly new valve cover gasket, etc. type stuff.
This is not the ideal wheeler that I was planning to build, but it seems it might make sense as a starting point. I'd want to put 4:56 gears and a locker in the back (use my D44). Wasn't quite so sure about the ProComp kit.
So whadda ya think? Good deal, or let it pass?
mwm said:
Go for it. It will cost you more to buy one and lift it urself. I bet your going to need a SYE in a bit.
really ? the guy your buying parts from is raping you then.
Offer him $2800.00 see what happens...
Yep, that's exactly what I was thinkin'. Figured I'd throw 4:56 gears in the front and build my D44 rear axle with locker and 4:56 and swap in later. I can use my existing brutalized Cherokee (also a 89) as a parts car since I just got through replacing all the worn giblets (CPS, plug wires,rotor, cap hall effects sensor, water pump).
Not exactly the front lift kit I choose, but suspect it will work fine for a while (I was planning RE 5.5).
The fact that it has a cherry interior is what's throwing me over the edge.....
I didnt relise this was in USD. Im in Canada..3800s a bit steep but a 6" Re lift with full leafs dont come cheap. Id offer 3000-3200 and see how it goes.
Yeah, I'm thinking that's the price range to offer. Cherokees keep there price pretty well up here. Real popular car with the soccer-mom crowd and all the snow. No doubt I could do better in Sac-of-Tomatoes, but the gas alone for a couple of trips to check 'em out would negate any savings it seems.
Thanks for your input.
FOR AN '89??????
holy smokes thats expensive, I dont care if its got solid gold leaf springs, thats way too expensive. I just bought a 98' for 4,400....
EDIT: Didnt realize you arent in the rust belt. Things are cheaper up here...
kbb list private party as 2100 for stock, so somewhere between 2800-3000 I would think would be fair. Probably have to change the shocks out, SYE....
Heres an example in Utah,
89 XJ, 8" skycrapper RR, 30/35, 4.88's, detroit/ARB, laredo, immaculate inside and out, strong 4.0 form a 95, 40k on whole drivetrain, used offroad, not abused, 35 MTRs with less than 5k miles.
I picked it up for 2500$
89 XJ limited, 9.5 rustys/RE/RK longarm, 30/44, ARB's, leather, turret (sunroof), 35 BFG's, good engine 200k miles +, traded for a POS 90 VW jetta that I had 700$ into.
Moral of the story is the 4x4 community is pretty dead right now and is a buyers market, atleast out here with gas prices the way they are, you not going to sell for anywhere near whats into it.
I agree offer mid 2's and go from there.
Jesus...Utah here i come
