Pressure regulator Tire Inflator?
IMORTL
NAXJA Member #1156
Corona
I just installed an OBA tank and QA2. I want to get a pressure regulator and set it for 33lbs and run 4 lines off of it for the tires... Will I be able to clip the valves on and let it go and have it stop when it hits 33 lbs? I am trying to avoid having to kneel down and keep checking the pressure... I woudl like to be doing other things like packing up and connecting sway bar links...
is this a dumb idea? or will it work?
ken
ken
Yes to both questions :D
It will take hoses and clip type air chucks to all tires running to a central manifold block, running to a regulator, running to the quick connect.
