Power Windows
93XJMan
Hey, I got a 93 XJ and I have power windows. It seems that every window execpt the drivers window seems to go down slow. They all go down but those three go down slow. I do use the drivers window more, is just that the other windows aren't getting used enough?
Thanks,
Alan
It could well be that the track is just dirty from non use. Pull off the door panels and spray some spray lube (preferably not WD40) along the track while rolling up/down the windows.... You can also check the wiring to the motors, I hear that's a common problem on XJ's with power windows and locks (I wouldn't know, since I have power nothing ;) ).
Hopefully it's not just the motors dying slowly on you, but that is a possiblity.
