f-a-t-b-o-y
- omaha, NE
1995 mazda mx6 2.5l v6
it had a small leak but operated normaly. after other repairs and bumpin it it began to drizzel. well after sittin for two days, all the fluid drained out. now, not thinking about it we started the car and the power steering pump is screeching like a coyote in a trash compactor! ew put fluid in it( even though it was draining out) and the noise did not stop. it did have a TON of air bubbles in it though. would the air bubles cause the noise? would i have killed the pump or will it be fine if i replace the leaky hose and refill it? any help you guys can give is greatly appreciated. thanks in advance.
