Power Antenna Woes
desertred
My guide for the power antenna on my 88 Cherokee must have broken as it is stuck in the raised position and the motor just keeps runnign with no mast movement. I have worked around this by pulling the fuse, but as you can imagine, this has gotten old. I wanted to turn my power antenna into a standard one by disconnecting the motor. However, as I was attempting to remove the inner fender, I found the the nuts securing the inner fender were frozen and started to break them off. So, I nixed that idea. Next, I tried to disconnect the antenna relay harness from under the dashboard, but could not get the harness connector out of the relay for the life of me! I do not have the factory electrical diagrams. My question is: can I just cut the wires running between the relay and the power antenna to kill the antenna motor without affecting the operation of any other components? Does anyone know where I can get the nuts and bolts to secure the inner fender if I have to return to that method?
Yes, you can cut the wires to the relay, but I would tape them up on the then-bare ends, to avoid a short later.
If you want to fix this more professionally, the bolts that hold the inner fender on are actually studs that are welded to a bolster plates that attach the urethane fender flare on the outside of the metal fender.
I broke almost all of my studs off when I changed my power antenna to a fixed mast type. I fixed the broken stud problem by drilling out all the broken studs, and pressing in carriage bolts into the bolster plates. The end result was a professional fix that took me about 2 hours on the bolster plates (therre are 3), and about 2 hours on the antenna itself. It was a long afternoon........
