post orgs over axle track bar bracket
thompson97
harrisonburg, va
just finished welding up the orgs OAB for my new track bar. for those of you that have done this (or similar welding mods to the dana 30) is it necassary to re-grease ball joints, u-joints, etc? change diff. lube? what about the pass. side seal? dont want to get in some water and find out all of that stuff is fried.
You shouldn't have to do anything. The little bit of weld that is on the actual Dana 30 tube is a long way from your axle seal and no where near your ball joint. You should be fine. Don't know what you were welding with but there shouldn't be a problem. I just did mine this weekend too. No worries.
John
