plugs and rotor... how often you guys replace them?
Kejtar
PostMaster General
I'm running I think on my 3rd set of plugs now and my xj is '98 with ~120K miles on it.... trying to decide if I need to do it again or not....
Kejtar
Not sure how often I replace mine, but I'll put it this way. I dropped in a new rotor, cap, plugs, and wires about 3 years (28,000 miles) ago and I REALLY need to replace them. So guess what my plan is for the jeep when I get back home.;)
Mike
In my '98 i replace the stock Champions every 25k miles or so. They are so cheap and so easy to do that may as well!! I like to also keep ck of the cyl/plug contitions that often too. However, i side-gap them before installing which could necessitate more frequent replacement. A good rule of thumb i have found is when there is at least .010" increased plug gap from wear with std plugs to be fairly ideal. At 25k there is not quite that on this, but does not matter. At 80k on this XJ the cap and rotor still look good. The wire replacement will be a matter of time in use i think, not mileage. Jury is out on that one so far-
