cncman
- Fitzwilliam NH
I picked up a 1988 comanche with a blown motor for free from my father. While looking for an engine i ended up getting a 94 H.O from my uncles shop for $50.00 with around 30,000 on it. I got it all swapped in and hooked up but damn this thing runs terrible. it idles at about 450 and shakes all over while billering out brown smoke when you give it some gas. I am positive the firing order is correct and am pretty sure everything is hooked up,but maybe i'm missing something the engine is for a auto but the truck is a 5-speed not sure if that matters but i used the H.O injectors with the non-H.O harness. hopefully some one can help. also where is the ''MAP'' sensor i was told if that wasn't hooked up it will do what it's doing now.
