play in the rear wheels
Dfete1
Palestine, Tx.
I jacked up the rearend today and both wheels slide in and out about 1/8". This is probably the reason for my rearend noise. What should I do? As soon as I get this taken care of, I'm planning a lift.
What kind of noise is it?
My 8.25 had at least that much movement, it is normal. There is some room between the cross shaft, c-clip, and spider gear for movement.
The noise comes on noticabley at around 30 and gets louder with speed. Once up to speed it's not as bad , but if you gas it it gets loud again. And coasting it pretty loud. It sound like it's louder on driver side.
Grinding
Squeeking
Rumbling
A throbbing rumble
metal on metal
ticking
growling
high pitched
low pitched
steady
thumping
etc...
I guess it would kinda be a rumble that starts off low pitched and get higher and louder when gaining speed. It seems like I can find a sweet spot on throttle and it won't be as noticable.
don't forget that if you have recently lifted your vehicle without a SYE, then that could be a source of your noise. If it sounds more like a grinding, could be that.
Soo that begs the questions:
- How much lift if any?
- How many miles?
- Stock gears or aftermarket? Aftermarkets for the 8.25 are noisier.
- More on acceleration, deceleration, or both?
It does vibrate a little, but I put all new u-joints on already. Trying to cure this same problem. I opened up the diff. and the teeth look sharp and there was no metal on the magnet. I filled it back up with fluid and no difference.
