my steering definitely feels loose. im suspecting the steering gear box because i can grab the steering column and twist it quite a bit with my hand. I know other things can cause the feel of loose steering so i guess my question is should i be able to twist the steering column that much or is that amount of play normal. i ahev attached a video.
http://youtu.be/HU0vBAfV0jg
i checked out everything else on the front end and it seems to be fine. no connections are loose or appear to be worn.
also i have to hold the wheel at 11:00 as apposed to 12:00 for the jeep to go straight. if i let go of the wheel it straightens out but the jeep drifts to the right.
thanks for any help
thanks for any help
