Barger
- DelaWhere?
I've recently installed a SYE in my 231 and the front output shaft has started to make a clunking noise because there is some play in the shaft. When I did the install there was not any movement. I've checked the front yoke nut twice and it is torqued correctly. When I had the case apart all the parts looked to be in good shape.
Anybody else had this problem?
What was the solution?
What may have failed? Bearings?
I plan on pulling the case back apart just trying to get parts before hand if possible so I can limit down time.
Thanks
Brian
Thanks
Brian
