Pinion Shim - What is too much
rmm727
USA
How many degrees of pinion shim would be too much our stock rear axles before pinion bearing starvation occurs
4 degrees, 6, more
just curious
Not to sure but just make sure the pinion bearings recieves enough oil. Try giving Tom Woods a call, they are very very helpful in answering any questions related to anything that has to do with driveshafts, u-joints, angles, slopes etc. :)
it depends on your current driveling angle, but ive read that 6* should be the limit of any shim, anything after that, you need to start thinking seriously about remounting the perches in the proper orientation so as to achieve proper alignment.
