BrianJr
- Blacksburg Virginia
I am getting ready to install a RE 4.5" Super-Flex lift on my stock 1999 XJ. The research I have done indicates that I have about a 50/50 shot of eliminating driveline vibes with the t-case drop that is included in the lift. Otherwise I will need a SYE. It has been recommended that I install the lift with the t-case drop and see how the XJ drives before ordering an SYE. I have two questions:
- How many degrees did you have to shim your rear axles with the 1" t-case drop? (to get the pinion angle to match the t-case output)
- How many degrees did you have to shim your rear axles with a SYE and RE 4.5" lift? (to get the pinion angle to point at the t-case)
[/list=1]
The reason I ask is I am also installing a new rear axle. My plan was to weld the spring perches on at the angle for question 1. I can then buy shims to get to the second angle (question 2) if I need an SYE.
I really need to get a good idea about question one. I have the replacement axle and need to get as much done on it as possible before the lift goes on. I am borrowing garage space and don't want to overstay my welcome. So I want to get the spring perches welded on before the lift arrives so that everything is ready to go.
Thanks,
-Brian
BTW: In case it matters for some reason the current axle is a Dana-35 and the new one is a Ford 8.8"
