snwboardxj
- Virginia
Hey guys,
This is my first post on the board, but I've been reading through the board since I first got my XJ, and there's a wealth of knowledge in here. I'm hoping you guys can help me clear up my confusion with rear pinion angle. I've got a '98 XJ and recently installed a 3.5" RE Super Flex lift kit, and since have had vibrations at lower rpm's, and a grinding noise when I let off the gas. Here are my measurements....
Rear Knuckle - 7.5 deg up
Rear of Rear Drive shaft - 18.5 deg up
Rear Working angle - 11 deg
Front Knuckle - 4.5 deg down
Front of Rear Drive shaft - 18.5 deg down
Front Working angle - 14 deg
Now from everything I could find within the board and online, I want my rear working angle to be about 0.5 degrees less than the front working angle, which would mean I need 2.5 deg axle shims. But then I've also read that I want the rear working angle to be as close to zero possible, which would mean....11 deg shims?!? I've read most people are using 4 deg shims with this set up, I'm thinking I need 2.5 deg shims, but if you guys could clear up the confusion, it'd be much appreciated!
